je viens de constater que j'ai pas l'option UP et UPd dans le menu (fonction tete en bas).
est ce que quelqu'un a deja ue ça et a trouvé la solution
a part ça, cet apres midi je vais la tester pour la 1ere fois en 720p et 30 image par secondes (r2) on verra ce que ça donne ![yeah [yeah]](http://www.streetriple.fr/Smileys/default/coolfuck.gif)
Hello,
Je joins les réponse que j'ai eu de GoPro sur mes problèmes...
Résumé : Une mise à jour est à venir "coming soon".
- I didn't manage to turn video mode on. It didn't work. As soon as I put on the shutter, Led blinks 3 times as if the camera turn the video mode off.
The problem don't come from my Kingstom SDHC card 16Gb class 6 since I test it with my photoshoot.
I think the problem come fromm the software which is not up-to-date.
Sorry to hear you are having some issues with your Hero camera.
It sounds like there may be an issue with your SD card. Please ensure that the tab on the SD card itself is not in the "locked" position. You may also try reformatting the SD card to see if it helps remedy the issue. - Where can I download the free update patch which allow me to obtain this feature : "Upside down image capture" ?
We are currently developing a number of different features such as the UP and UPd settings that we will be releasing as soon as possible in a firmware upgrade. You will be able to download the firmware upgrade from our website at no charge once released. To be notified when the updates are released please sign up for our newsletter at: http://www.goprocamera.com/newsletter/
In the meantime, if needing to record upside down, some video players and most editing programs such as quicktime pro will allow you to rotate the image. You can do a search in the help section of your particular program for 'rotate image', and you should get further instructions on how to do so.I didn't find my seral number, where is it ? Because it's not on the warranty paper...
The serial number for your camera is located in the battery compartment directly behind the battery.
